erkinfl
Dec 10, 2021Aspirant
RBR50/2 satellites - fast internet speed, slow wifi
I have an RBR50 with two RBS50 satellites. FW version on all is 2.7.3.22. My router is a Netgear CM1000. In the Orbi app, it reports my internet download speed as 360Mbps. But in my phone, Speedtest reports I'm only getting ~20Mpbs downloads, and I've been having sporadic connection issues for weeks. I've tried resetting the satellites. Kind of at my wits end here because I'd love to blame Comcast but I don't think I can. Any ideas? FWIW, this setup used to work flawlessly - I'm gonna say it's been problematic going on a month now.
EDIT - saw similar posts AFTER I posted this. Seems I'm not the only one. Might have to try downgrading the firmware. Has anyone figured out which is a good version to revert to?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless SettingsOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- erkinflAspirant
Home size: 1530 sq ft. 1st satellite is ~35 ft. from router with two walls between. Second satellite is in separate garage, ~80 ft away? That was a wild guess. But as I mentioned, this setup has worked flawlessly for several years.
I'll take a look at the other options you've suggested, thx!
A factory reset maybe needed as well...
