LanceD
Aug 03, 2025Guide
RBR50/RBS50 system slows every morning
Recently moved and dug out my admittedly aging Orbi to improve the WiFi in my apartment. I've got it so it can work great--up to 550 mbps at my desk (I have Comcast 600MB service). On the Or...
Aug 04, 2025Guru - Experienced User
How big is this apartment? Sq ft?
Does this happen with the RBS turned OFF?
MIMO should be enabled
Can disable 20/40Mhz.
Be sure to disable any MAC Address randomizers on, PCs, phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Might try a factory reset and setup from scratch:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
