indinsg's avatar
indinsg
RBR50v2 - Issues post Firmware update
Hi,
Just did a firware update and having issues connecting to the Orbi app. It asks for the admin password, which i entered with the default password. Does not go in. Tried resetting the admin password on HTTP://orbilogin.com, takes me to a page to answer two questions, which I have no recollection of setting up, so no luck there. Tried deleting that app and reinstalling, same issue. Anyone with any suggestions on how to overcome the admin login issue? I have not changed the default when I had setup.
Thanks in advance.
Regards
Lucose
  • The default Gateway IP address of your Orbi is 192.168.1.1.
    • indinsg's avatar
      indinsg
      Cant ping 192.168.1.1 when I connect to the WiFi on my desktop. Attached network configuration from my mac.
      • vajim's avatar
        vajim
        Master
        What is your modem?
  • I'm having the same issue after I tried rolling back firmware. The only thing left for me to do is factory reset...
