DebF
May 07, 2020Aspirant
RBR50v2 setting up says check ethernet cable
set up stops at check ethernet cable-- have tried different cable retry same result
using Netgear ATT wireless modem to connect to could modem type be problem
really asking how to set up I am following instructions retried several times same result check ethernet cable
If the ISP modem already has a wifi router built in, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThe modem maybe using same IP address of 192.168.1.1 which the netgear orbi uses as well. You should be able to factory reset the RBR and walk thru the setup wizard and it should change the IP address to something else if this is the case.
- DebFAspirant
thanks for response
Modem I am connecting Orbi to
NETGEAR
Model: MR1 100
thank you
