wisesam's avatar
wisesam
RBS20 Poor Backhaul Status
Hi Everyone. Just wondering if anyone experienced a sudden poor backhaul/disconnects? My orbi runs fine where they were in the last 1.5 years.
Now it's been a week where the satellite just won't sync to the router. I even put them close to each other within a meter and it shows "Poor Backhaul Status" The moment I put it back where it was then it'd just disconnect.
In dillemma whether I should get another RBS20 (1.5 years running and started doing this? shocking quality) or newer Orbi and don't learn my lesson after 1.5 years with Orbi or switch brand.
Anyone has similar issue? firmware is the latest V2.7.3.22 for both router and satellites. Certainly not happy with this **bleep**ty quality Orbi
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    • wisesam's avatar
      wisesam
      Not sure it is fibre broadband modem to ethernet
      around 180m2
      building made by bricks
      distance about 15m away (in the last 1.5 years)
      distance now 1m away (with poor backhaul status)
      yep 4 detected from PC
      Yep
      Seemed like the satellite is faulty
      • FURRYe38's avatar
        Try placing the RBS closer to the RBR. Say 5-10 feet closer?
