lando786
Mar 12, 2020Aspirant
RBS50 Bricked?
So I'm not sure what changed recently but all of a sudden my RBS50 satellite was not connected to my RBR50. I tried rebooting via power, no white ring LED is visible, just the green power light on the back of the satellite.
I waited a good 10-15 mins and tried removing from RBR50 and re-syncing with no success.
I've tried pressing the reset button on the RBS50 but no matter how long I have it presssed, it just stays green, never reboots or factory resets.
I just saw there was a recent FW update, I wonder if it got auto-updated and failed half way through. This was on a wired backhaul and was operating normally for months.
I've seen some posts recommending flashing via direct connection and tftp, but my pc doesn't even recognize the cable plugged in (tried on several pcs and several cables) when I turn the satellite on.
Has anyone seen this type of behavior before and is there a way to revive this satellite?
- tomschmidtVirtuoso
If you are still under hardware warranty, then contact Netgear for an RMA.
you can try a tftp procedure to recover it
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure you enable it within windows
- lando786Aspirant
I tried this but my pc doesn't even recognize the satellite as being connected. Sadly im out of warranty period and outta luck it seems.
- Retired_Member
how do you know your sat is not connected? What are you looking at? What's connected to the sat?
