billypatel's avatar
Mar 12, 2022
RBS50 pulsing white permanently
Hi
I have had a orbi rb50 and an rbs50 working moslty ok for the past few years.
This is in a uk household with virgin media.
This week, the satellite has stopped working, and just pulses white.
I have tried many times to do a factory reset without luck.
I have trawled the depths of the internet for solutions and the one i keep seeing is to tftp previous firmware to the router.
That is the bit that is confusing me, the router is working fine. So how does tftp older firmware to the router fix the satellite?
Should i not be instead tftp'ing the older firmware to the satellite?
I tried connecting to the satellite via an ethernet cable but i cannot connect to it, despite setting my local ip to static etc.
Anyone have any info on how to revert the satellite FW to an older version?
  • plemans's avatar
    Does the satellite work if you hardwire it into the router?
    • billypatel's avatar
      billypatel
      Tutor
      when you say hardwire? you mean an ethernet cable from one of the router ethernet socket to the satellite? if so then yeah, i tried that, still pulses white.
      • plemans's avatar
        the default ip address for a factory reset satellite is 192.168.1.250
        any luck using that to access it if you have a hardwired in pc/laptop?
