Fastrac
Mar 08, 2021Aspirant
RBS50 satellite Connected Devices - Device names - Unknown in web browser
Can someone please tell me how to fix this problem.
I've had an RBK50 system for several years which has updated the firmware successfully up to and including version 2.3.5.30.
After each update the satellite connected devices list correctly displays each device name when viewed in a web browser window.
Any version of firmware from 2.5.1.8 or newer the satellite connected devices list shows Unknown where the name should be
when viewed in a browser window. The currently installed version is 2.7.2.104 and the problem still persists.
I have factory reset the satellite 4 times, the router 3 times and after the last factory reset I did a full new setup configuration
manually (not by loading a backup configuration). The system has also been powered off for >1 minute several times.
After the last reset I changed the router to AP mode (as I have always use it), and entered all the device names again; these show
up correctly in the router list and in the satellite list in the app but not in the satellite list in any web browser window which still
shows Unknown. A partial screen shot from a web browser is attached to show the problem.
If I flash the firmware back to 2.3.5.30 the device names in the satellite work correctly again when in a web browser.
The router is a TalkTalk Sagem Fast Wifi 5364-3.T8 and some but not all devices have fixed IP addresses set by this router.
Does anyone know how to fix this so the satellite device names work in a browser window or is the only fix to flash back to 2.3.5.30?
I flashing back to the older version is the only way to fix it, how serious are any security issues?
Thanks.
- vajimMaster
I've seen the problem you describe for several weeks. I tried rebooting and the problem remained.
The list in the PC login was wrong for all of my devices were fine as well as my sats.
Last week without any further action by me, the list now appears to be correct. I don't look at all that much but it certainly shows the sats connected.
My FW is about as old as your (6 months +) so I don't think it's related to FW.
- FastracAspirant
Fastrac wrote:Can someone please tell me how to fix this problem.
After the last reset I changed the router to AP mode (as I have always use it), and entered all the device names again; these showup correctly in the router list and in the satellite list in the app but not in the satellite list in any web browser window which still
If I flash the firmware back to 2.3.5.30 the device names in the satellite work correctly again when in a web browser.The router is a TalkTalk Sagem Fast Wifi 5364-3.T8 and some but not all devices have fixed IP addresses set by this router.
Thanks.Hi,
Does anyone have any suggestions what else I can try to fix the issue of Device Names showing as Unknown in the satellite connected devices list ?
Is the only option to roll back the firmware to 2.3.5.30 which is the last version where the names were correctly displayed ?
If I have to roll back the firmware, how can I stop it updating to a later version ?
Thanks
- vajimMaster
Fastrac wrote:Hi,
Thanks
Not sure of the cause for as I said I see the same thing, Sometimes I check the device list and it's whacked up and other times its fine. I try not to look at it anymore.
Netgear susposedly only pushes firmware updates that contain critical security feature. I'm not even sure that is happening. All other updates are caused by you clicking something.
Fastrac wrote:
Is the only option to roll back the firmware to 2.3.5.30 which is the last version where the names were correctly displayed ?If I have to roll back the firmware, how can I stop it updating to a later version ?
I observe the same thing:
- Attached Devices on the Orbi router correctly displays the name, model, "type", and cute picture.
- Connected Devices (not "Attached") on the RBS50 and RBS40V display "unknown", with the exception of two entries on the RBS40V that do not match the router.
This definitely is related to firmware, since version 2.3.5.0 works correctly and more recent versions do not. The choice appears to be (a) stay on 2.3.5.0, or (b) stop looking at Connected Devices on the satellite.
The user has no mechanism to stop firmware from updating.
Have you actually experienced the Orbi updating firmware without any action on your part?
- FastracAspirant
Thanks for your reply.
Going back quite a while I would get a notification of new firmware available when I logged into the Orbi and had to click on the notification to install it.
Recently I have seen some posts in other peoples threads about theirs being updated automatically overnight.
I don;t want to roll back to 2.3.5.30 and set everthing up again, then Negear automatically update it to a newer/problematic version 'overnight'.
Many things come and go on my Orbi and I like to keep track of whats connected to ensure only what should be on the system is connected.
Having working device names makes this much easier that looking at IP addresses.
