Boppy's avatar
Boppy
RBS50 satellite will not update V2.7.4.24
I was able to manually update the RBR50 router but not the RBS50 satellite.  The message:
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
Help!
  • The Attached Devices page shows the IP address of each satellite.
    In the web browser, enter that URL (e.g. http://192.168.1.5)*. Enter the web password. Firmware Update is the bottom menu item.
    * If I had 'planned ahead', I would have left IP's 2,3,4,5 for satellites, but I was so intent on installing the Orbi that I connected two PC's and a printer before activating the satellite, which then got IP #5.
  • This often happens when (a) trying to upload a router file to a satellite (they have distinctly different names for the *.img file), or (b) the file got corrupted during download and needs to be downloaded again.
    I prefer to connect directly to the satellite web interface to do a firmware update.
    • Boppy's avatar
      Boppy
      Thanks for the quick reply, but I did use the RBS50 img file and downloaded it twice in case it was corrupted.
      I see a new post that says do RBS50 before RBR50.  I tried the automatic option three times and then tried the manual.  RBS50 failed but RBR50 worked.
      Where do I go from here?  Do I need to do a factory reset?
      • CrimpOn's avatar
        CrimpOn
        Guru
        A factory reset on satellites is totally painless. (They have nothing to configure.)  Can't hurt.
        It is not clear to me whether you are using the router's Firmware Update menu, Manual Update tab or are connecting directly to the satellite's web page.
