m4f1j0z0's avatar
m4f1j0z0
RBS50 shown under "Connected Devices", but not under "Connected Satellites"
I have Orbi RBK50 in AP Mode with ethernet backhaul. I ran through all possible suggestions from this forum on how to get the enternet backhaul working properly (posts like this one https://community.netgear.com/t5/Orbi/Steps-to-reproduce-the-Orbi-backhaul-issues/m-p/1516065#M24646).
The Satellite RBS50 is connected, and it works fine over ethernet backhaul, but under connected devices on the Orbi Admin Page it isn't shown as a satellite, but as just another connected device. Why is that?
My setup is: ISP Modem (in bridge mode) -> Router Asus RT-AC68U (with Merlin) -> Orbi (RBR50 & RBS50 in AP mode). Cableing is fine, I have tested each ethernet connection separately.
As far as I can tell, speed and roaming performance are both fine (500 Mbit over WLAN), it's just pissing me off that the satellite isn't recognized as a satellite, and I dont understand why. Do you guys have an idea what's going on?
See the picture attached, the satellite has the IP 192.168.1.61.
  • OK, problem solved. I just remembered that someone suggested not to connect the RBR50 to the router through the WAN port.
    I just moved the cable to ETH1 port, restarted the RBR50 and RBS50, and voilà, the RBS50 shows normally under connected satellites.
    Really this Netgear software / firmware is ridiculous. I might switch to Linksys Velop just out of principle.
  • FURRYe38's avatar
    Is the satellite working ok?
    Is the satellite directly connected to the base or thru a switch?
    • m4f1j0z0's avatar
      m4f1j0z0
      The satellite is working fine. It's connected to the ASUS Router, just like the RBR50.
      • m4f1j0z0's avatar
        m4f1j0z0
