MarcusTan93
Feb 03, 2021Tutor
RBS50 WiFi No internet
Hi,
I have a RBK50 System (RBR50 +RBS50)
I am having issues with RBS50 Internet Connection.
1. RBR50(Router) has no issue connecting to the internet. Both on Wifi and Ethernet
2. RBS50(Satelite) is linked with Ethernet Backhaul.
3. My PC connecting to RBS50 via Ethernet has no issues connecting to Internet
4. My devices have issues connecting to internet when connecting via RBS50(Satelite)
5. My devices have no issues connecting to internet when connecting via RBR50(Router)
6. RBS50(Satelite) firmware is RBS50-V2.7.2.104
Should you require more information to diagnose , do ask along :)
Oh well. I just factory reset the RBS50 sat and resync the sat to the router. Magically it works now...finger crossed this issue won't happen again. Thx for your input anyways vajim
- vajimMaster
MarcusTan93 wrote:Hi,
6. RBS50(Satelite) firmware is RBS50-V2.7.2.104Should you require more information to diagnose , do ask along :)
how do know which of your devices are attempting to connect via the sat?
Hi Vajim,
1. By going to the attached devices section(via router and satelite admin page)
2. By signal strength. If it is connected to the router, it will at most has 1-2 bars max(My router is quite a distance away and it is at lower floor). If it is connected to satelite, it will be full bar.
- vajimMaster
MarcusTan93 wrote:Hi Vajim,
That's what I thought.
Are any of your devices hard wired into the sat?
FYI....just checked my pc login and it says both of my sats disconnected, yet in the devices lists it shows several connected via one of the sats.
Sometimes a simple reboot makes all happy
