mnagie97
Jun 02, 2022Aspirant
RBS50v2 won't connect
One day last week this satellite would not connect to the router.
It has been working fine for a long time.
I do see my other satellite with no problem.
I have reset it to defaults and even put the satellite right next to the router with no luck.
I hit the sync button and eventually I do get a blue light so I guess it sees the router.
Still nothing.
I even got a new satellite and it didn't work either so its sounding like the router itself.
Does anyone have something else I can try.
- KevinLiTNETGEAR Moderator
Hello mnagie97,
Welcome to the NETGEAR Community!!
I understand that you are only able to see one of the satellites connected to your network.
Which firmware are you on?
What is the model version of the satellites synced to your RBR50?
Best,
Kevin
Community Team
