WAP
Jan 15, 2018Apprentice
Ethernet Backhaul Best Practices
Two questions/clarifications (1) RBR50 is in AP mode. The RBR50 is connected to the ISP router using the RBR50's yellow WAN port. Going to try ethernet backhaul but wanted to do my homework first....
- Jan 15, 2018A large switch with other devices is fine. I would just try the different combinations until you are happy. I concluded it was working fine only when the satellite showed up in the satellites list and said it was using a wired connection, even after a reboot.
