Doug-48051
Jul 06, 2017Luminary
Firmware Roll Back Question
Since auto update can not be disabled is there the ability to roll back to a previous version? Also would it be possible to add a schedule time of day for an update? I only ask b/c a router reboot ...
- Jul 06, 2017
hi
it would be pretty useless to roll back as the orbi would just try and update its self automatically afterwards
i do agree there should be a setting to select when its done and will ask the beta team to investigate if it can be added
peteytesting
Jul 06, 2017Hero
hi
