agneev's avatar
agneev
Re: mini UPnPd doesn't update
Continuing the discussion from 1766998....
This issue has still not been fixed with the latest version of Orbi firmware and makes it impossible to track router data usage in apps that support miniUPnPd.
Blanca_O Christian_R
    • agneev's avatar
      agneev
      FURRYe38 wrote:
      Have you tried Voxels FW?
      I'm not too sure about going that route because a lot of things can go wrong.
      Does Voxel have the same UI as NG and is the mobile app compatible?
      • FURRYe38's avatar
        Same UI with minor icon imporvements.
        Yes.
        I haven't seen things to wrong with Voxels FW while using his FW. Only 1 issue currently is that to reset the system you have to load stock FW back on to the RBR. Voxel is working to correct this item currently.
    • agneev's avatar
      agneev
      Just flashed and tested, alas no, the issue is present there too.
      Is there another way to get (daily) data usage?
  • CrimpOn's avatar
    CrimpOn
    Far above my competence level.  It is pretty clear that upnpc.c defines the byte counts as "unsigned int" (line 122), which indeed has the maximum value of 4,294,967,295.  This is where I flounder: the function call to retrieve the value.  Is is wanting an actual binary unsigned int, or is it retrieving a character string and converting it?  Back in the days that upnpc was being written, devices that did multi gigabits in one reporting period might have been unusual.
  • Also, when 4294967295 bytes is reached for either download or upload, the KiB/s sensor for that also stops responding.
    • FURRYe38's avatar
      Something to ask Voxel about. Or if on stock, file a support ticket.
