tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
Jan 01, 2019Guru - Experienced User
EIther by NG or the chipset developer or both. Again, for the average home user, simplicity is desured. The less users have to do with there systems, the better. I most cases, there is no need to change channels on the satellites. This is handled by the router.
molec wrote:
FURRYe38 wrote:
Users need to remember that the reason why you can't pick channels on the satellites is that they are acting as REPEATERS/Extenders, thus when repeating, they have to be on the same channel as the source wifi signal channel. This doesn't work if the satellites was on a different channel from the source wireless. Repeatersand Extenders work on the same channel for this configuration.
This is circualar reasoning? WHY are the satellites acting as Repeaters/Extenders? It's by design choice of Netgear, I assume.
tln741
Jan 01, 2019Star
So extensive co-channel interference is a feature, not a bug, for NG.
If that is the case, then NG should make that clear in their documentation so us advanced users do not waste our money on a poorly designed product.
