Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
ianstephens
Mar 03, 2018Tutor
How did you fix the issues with Orbi and Ring devices? We are too using Orbi Pro with one base and one satellite. Did you change anything specifically or do anything "special" to make them work?
rmadilao
Mar 03, 2018Guide
I've gone through multiple mesh router systems over the past 3 months. I finally settled on Orbi Pro as it's actually the best of the bunch for my physical environment. First and foremost, make sure your router and satellite are not too close together. This will help with Ring cam devices wandering between nodes.
Maybe it's easier to tell me what you've tried. In my case, I stripped down the system from all the advanced features and started from basic. As I got it working, I added back the advanced features of the Orbi Pro, one by one. I've pretty much tried everything possible and it all works great now.
What is the worst issue you are dealing with right now? No live view?
