OldbeeNewbee
Sep 20, 2017Follower
Orbi Firmware update
When checking my firmware updates my ORBI RBR50 router shows an update. Then the SatelliteRBS50 says "please wait a moment....." is something every going to show up. Ithas been a while.
- Sep 20, 2017
If you're not having any issues with your current firmware I'd suggest you don't force it, and just ignore that.
If you are having issues, then you can get the 2.0 fimware from https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
aaz
Sep 20, 2017Virtuoso
