AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
aucman
Apr 14, 2018Star
Yesterday i have made a reset on firmware 2.1.3.4. Connection drops on mobile device if this device is connected to the satellite are still present. I have to disconnect and connect again. Sometimes it takes relatively long to obtain an IP address. I am in router mode.
Bullyterrier
Apr 14, 2018Star
I too still get internet blocked on mobile device after (overnight) sleep.
Beta firmware, full factory reset of router and satellite and mobile device network reset (all together) tried. Further 'forget' of network tried too.
iPad pro iOS 11.3 - WiFi connects on resume but any internet access hangs until/unless WiFi on device switched off and on. Then resumes until the next time.
Router in router mode with (certified) Drayton fibre modem driving BT Openworld fibre to the cabinet.
In passing I also get 4mb less upstream speed than with the old 2 X Apple extreme install and 2ms greater latency.
- turns2stoneApr 14, 2018Apprentice
Are you using the iPad Pro 9.7? That is the only device I'm having issues with disconnecting, so I'm not sure if it's the iPad going bad, or the Orbi.
I'm running 2.1.2.18 on my RBR50 + RBS50 (2) and 2.1.2.20 on my RBS50Y.
In a few days, I'm getting my internet speed upgraded from 50Mbps to 1Gbps. I'd like to start using wired backhaul to take advantage of the increased speed from my ISP. What firmware version should I look to upgrade to?
- BullyterrierApr 14, 2018StarYes it's a pro 9.7 - I use it all over on loads of networks and no issues except on the Orbi.
My router and satellite are on the beta from this thread (the issue happened on the previous code too). - turns2stoneApr 14, 2018Apprentice
Thanks. Wonder if the iPad Pro 9.7 has something in its Wi-Fi chip that the Orbi doesn't like? It's kinda driving me crazy at this point. Usually a reboot of the iPad fixes it.
- FURRYe38Apr 14, 2018Guru - Experienced User
Beamforming, MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router.
Try upgrading to a Beta version of FW and see if this does anything different?
turns2stone wrote:Are you using the iPad Pro 9.7? That is the only device I'm having issues with disconnecting, so I'm not sure if it's the iPad going bad, or the Orbi.
- raven_auApr 15, 2018Virtuoso
Hi all,
I've put my Orbis back in service and I've installed the latest 2.1 firmware, it's been running for a maybe a week now.
Last night the Orbi router stopped responding while watching a movie.
But this time I saw it was rebooting, I think this is also what has happened at least once before and matches with what others in this thread have seen.
This is almost certainly a kernel crash.
My question is, do any of the logs that support request contain kernel back traces if there are any?
It's next to impossible to resolve problems like this without such a trace and even very hard with one.
Ian
- turns2stoneApr 15, 2018Apprentice
Thanks, I will give that a try.
So I got Ethernet backhaul working. Question: Should all wireless devices now show their connected to the Orbi Router? When I was using Wireless backhaul, each device near the satellite would show they were connected to it. Now 100% off my wireless devices show connected to the Router.
- Sdiver2489Apr 15, 2018ApprenticeMy orbis are connected with Ethernet backhaul and I have devices that show connected to the satellite. I think devices that are wired to the satellite show up connected to the router but wireless devices still show that they connect to the satellite when they are far enough away from the router.
- BullyterrierApr 15, 2018StarIn case anyone from Netgear is here I have this iPad internet blocked after sleep issue open as case 29999148 and am happy to gather debug info if required. The support rep asked where I obtained the beta so I replied today re this thread. The rest of the response was not helpful in progressing the issue.
Bullyterrier wrote:
In case anyone from Netgear is here I have this iPad internet blocked after sleep issue open as case 29999148 and am happy to gather debug info if required. The support rep asked where I obtained the beta so I replied today re this thread. The rest of the response was not helpful in progressing the issue.So yor not using an RBR50 or RBS50?
The firmware for those is available on the Netgrear support site.
- FURRYe38Apr 15, 2018Guru - Experienced User
wireless devices when connected should show connected to the satellite when there connected there. If there connected to the router, they will show at the router.
turns2stone wrote:Thanks, I will give that a try.
Did you factory reset the router and Satellite(s) after you upgraded to v2.1.3.4? This needs to be performed for this version of FW.
raven_au wrote:Hi all,
Ian
OK that's what I thought.
Turns out, wired backhaul is just too unstable for me. The entire network crashes! I'm running 2.1.3.4 on RBR50 and RBS50 (x2) and 2.1.2.20 on the RBS50Y.
Did I need to do a full factory reset? That seems like a major pain.
Is there a FW update for the RBS50Y? Might be a problem here.
There any networks switches between the satellites and router?
Please factory reset the router and RSB50 units then set up from scratch.
My wired back haul is working fine. You have to give it time to reconfigure for the new connection?
Are you connecting all satellites at the same time for wired or doing one at a time and giving it 5 minutes to reconfigure?
Others are reporting success after a factory reset and set up from scratch:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
turns2stone wrote:OK that's what I thought.
Yeah, this is a mess.
I factory-reset EVERYthing. Brought the router back up, it found the outdoor satellite no problem. Everytime I try to sync a wired satellite, the entire network crashes as its being setup. It’s almost like the router figures out its wired backhaul and just pukes.
When setting up wired back haul, are you first setting up the satellite via wireless and is it working at this stage? It should be. Then connect the LAN cable between the router and satellite and give 5 minutes before you check the network? It needs a good 5 minutes. Yes the network may seem to stop working, however give it time. After 5 minutes it should be stable and working. Do one Satellite at a time.
Possible that there is something wrong with the satellite in this configuration. Something to contact NG support about if you can't get it working on LAN back haul. Others including me have wired back haul working...
turns2stone wrote:Yeah, this is a mess.
FURRYe38 wrote:Did you factory reset the router and Satellite(s) after you upgraded to v2.1.3.4? This needs to be performed for this version of FW.
Yes, all Orbis were factory default reset and configured from scratch, it happened less than 24 hours afterwared.
There's more, the device I was using might have been connected via an RBS40 satelite with 2.1.3.6 to my RBR50, unfortunately I hadn't checked.
Are you able to answer the question I asked?
Also, I've enabled Circle.
Can you disable Circle and see if the problem still happens while watching a movie?
How are you watching movies? What kind of device? Mfr and model#? Thisdevice wired or wireless when watching movies?
As far as logging, not sure about the logs. You might enable them and send them to your email address and check them out.
- raven_auApr 16, 2018Virtuoso
@@FURRYe38 wrote:Can you disable Circle and see if the problem still happens while watching a movie?
The device was an Apple TV 4K and in this case it was the Apple Movies app.
I have had the impression in the past that certain devices wireless can cause problems, such as NUC D54250WYK, and connecting that via ethernet cable resolved my problem at the time. I've done the same thing for this particular Apple TV 4K, I've left my other one as wireless to see what will happen but I'll have to wait until it gets more use.
I find now that others in my household have had what appears to be a disconnection problem over the last several days, I've asked them to check if the router is rebooting when it happens and let me know. AFAICT this was while using an Apple TV (previous version to the 4K). I hadn't had problems with Apple devices previously so this is curious. The Apple devices have all updated to 11.3 now, I believe, certainly the Apple TV are all on this version of tvOS.
I'll check disabling Circle if the problem continues and it sounds like I'll need to work out if the kernel back trace gets captured in the log myself. Often they happen to quickly to be captured in the logs and one needs to connect a serial cable to the router to get the backtrace.
I've got several usb serial devices but I don't want to pull my Orbi appart, assuming there is a serial interface on the board. Perhaps there is some other way to get serial access to the Orbi, anyone?
- turns2stoneApr 16, 2018Apprentice
Thanks. I got one satellite connected via Ethernet using this method. But can't get a second. It just shows connected via 2.4Ghz and shows Backhaul status as "Poor", even though Ethernet is connected.
- srgb111Apr 17, 2018Guide
A couple of things that helped me (not sure if they are all needed)
Factory reset
set up wireless connection to satellites first then move to wired location
Network connection to router should be to one of the lan ports
Turn off diasy chain
Turn off IGMP snooping on your managed switch
I'm running stable w/ correct reporting of "good" "wired" connection in the GUI
FURRYe38 wrote:When setting up wired back haul, are you first setting up the satellite via wireless and is it working at this stage? It should be. Then connect the LAN cable between the router and satellite and give 5 minutes before you check the network? It needs a good 5 minutes. Yes the network may seem to stop working, however give it time. After 5 minutes it should be stable and working. Do one Satellite at a time.
- FURRYe38Apr 17, 2018Guru - Experienced User
So do you have a managed switch? Whats the Mfr and model# of your switch please.
So disabling IGMP snoop seems to help on managed switches? This is good info. Was hoping there is something on these switches to help users that have them.
Thanks for letting us know. Will pass this on.
srgb111 wrote:A couple of things that helped me (not sure if they are all needed)
Factory reset
- turns2stoneApr 17, 2018Apprentice
Factory reset
Thanks. I did all that, except for turning off daisy chain. So maybe that's the source of the problems? - srgb111Apr 17, 2018Guide
It's a GS108Ev3, two actually. I have two sats - I set them both up with wireless backhaul. I then connected a wired backhaul for the first sat - this went through one GS108Ev3. After a short period it showed wired backhaul. I then connected the second, this time it was going through 2 switches - I waited for 1/2 hour or more with no joy. I then turned off IGMP snooping on both switches - for no good reason other than I've tried everything else...shortly after this change the second sat connected. From what I could read this shouldn't have made any difference, but the change resulted in the Sat showing up wired and I've been good since that point in time.
Now that I'm stable I don't want to tear it down to test if the IGMP snooping really was the key...
FURRYe38 wrote:So do you have a managed switch? Whats the Mfr and model# of your switch please.
Factory reset
srgb111 wrote:It's a GS108Ev3, two actually. I have two sats - I set them both up with wireless backhaul. I then connected a wired backhaul for the first sat - this went through one GS108Ev3. After a short period it showed wired backhaul. I then connected the second, this time it was going through 2 switches - I waited for 1/2 hour or more with no joy. I then turned off IGMP snooping on both switches - for no good reason other than I've tried everything else...shortly after this change the second sat connected. From what I could read this shouldn't have made any difference, but the change resulted in the Sat showing up wired and I've been good since that point in time.
Did you turn off Daisy Chain on the RBR50, as well?
