Re: RBR50 no longer detects satelites
Hello,
my satelitte is suddenly disconnected, i tried to pair or reset but no succes.
now i noticed in the orbi app that i see older firmware for that satelitte, so my plan would be to update it to 2.7.5.6 (from 2.7.4.24).
doing it via orbilogin is not going to work since it is not connected, so how do i proceed?
thanks!!
    • Crasje's avatar
      Crasje
      Tutor
      Hi,
      pressing reset does not work so far I tried it 3-4 times. Also turing it off for 5+min doesn't work.
      Today I hardwired (ethernet) the RBS50 to the RBR50 hoping it would make it visible for the ORBI management software so it could be updated via http://orbilogin.com (assuming only pairing etc was broken) but that did not work either.
      I have read somwhere that perhas connecting the SBS50 directly to a laptop was an option? But I can't find it anymore or how to flash it from a Macbook.
      • FURRYe38's avatar
        Try the link I posted about the self service web page.
  • Crasje's avatar
    Crasje
    Tutor
    Conclusion was that the Orbi RBS50 was beyond fixing, reseting to factory, rebooting, whatever... had no effect.
    So I spend a bucketload on the Orbi 873, very quick internet now đŸ˜
