PhysicalEd
Jul 12, 2017Star
Updated to V1.12.0.18, now Satellite will not sync, "Wireless AP: Off"
I just updated to V1.12.0.18, and now my Satellite will not sync. Everything was working fine on the previous version. I have power cycled both the router and satellite. Following this sugges...
PhysicalEd
Aug 21, 2017Star
5 weeks now...
My "Orbi satellite connection is up and running." LOL
- ronduluthgaAug 23, 2017Initiate
Adding another me too for this issue. downgraded to previous firmware and blocked download.netgear.com
Had two power outages in the last 4 weeks, and the satellite does not reconnect. Had one again yesterday (lots of storms) and it worked fine when they came back up under the previous release. PLEASE FIX.
- MHogueAug 25, 2017Aspirant
Netgear level 2 had me RMA my system and when I got the new one it worked well for a little while. I even tested power cycling it after the firmware update BEFORE setting my SSID and password.
Once I made those changes I made and then it stopped working after a power cycle. I'm going to try some different passwords and see if there is some character that may be breaking it.
- DarrenMAug 25, 2017Sr. NETGEAR Moderator
Hello MHogue
There is a known issue with special characters and spaces in the password causing issues and will be fixed in the next firmware.
DarrenM
