rdilauro
Jul 19, 2022Aspirant
Using two Netgear Orbi AC3000 RBS50Y to increase coverage range
We currently have on Netgear RBS50Y to extend our WiFi range from a main building down to the Lake front. Its about 750 yards. Down there I have 8 ARLO cameras connected to the same ARLO Base with ...
Jul 20, 2022Guru - Experienced User
I couldn't find the joowin devices but the Nanobeams are the same basic air bridge setup.
So for far distances, you want a point to point devices. For the close setup, thats where you want the AP's.
The arlo's usually run off their own hub (not all of them). Sounds like you have quite a few different vendors in your setup.
If it was me? I'd be looking at finding a single vendor and sticking with their solution so they integrate together better. I'm usually very pro-netgear but Ubiquity (your nanobeam) makes great stuff and does a really good job of integrating their various technologies into one solution.
rdilauro
Jul 20, 2022Aspirant
I am also a big Netgear fan. Ive been using them at home for over 15 years
Does the Netgear air bridge as dies the NamoBeams? I then assume I need a PoE switch connected to AC. ALL THE PoE switches U am aware of are fir Indoor use only. Can I use the Airbrudge just pointing to the Netgear wifi extender? And would I need any cables?
