rdilauro
Jul 19, 2022Aspirant
Using two Netgear Orbi AC3000 RBS50Y to increase coverage range
We currently have on Netgear RBS50Y to extend our WiFi range from a main building down to the Lake front. Its about 750 yards. Down there I have 8 ARLO cameras connected to the same ARLO Base with ...
Jul 20, 2022Guru - Experienced User
I couldn't find the joowin devices but the Nanobeams are the same basic air bridge setup.
So for far distances, you want a point to point devices. For the close setup, thats where you want the AP's.
The arlo's usually run off their own hub (not all of them). Sounds like you have quite a few different vendors in your setup.
If it was me? I'd be looking at finding a single vendor and sticking with their solution so they integrate together better. I'm usually very pro-netgear but Ubiquity (your nanobeam) makes great stuff and does a really good job of integrating their various technologies into one solution.
rdilauro
Jul 23, 2022Aspirant
I was told by the BestBuy Geek Squad that I could use two
Netgear Orbi Outdoor AC3000 RBS50Y, both connected wirelessly to the same Router.
One is currently connected, and they told me to wirelessly connect it to the same Router, then relocate the Wifi Extender
down to the lakefront, plug it in, no cables and I should get better wifi coverage.
Most other suggestions (including the one above) go for devices such as the Netgear Airbridge. I already have a JooWin CFW-E72 which also uses a PoE switch. But where I would put this device is outdoors and from what I ready, the PoE are not meant for outdoor usage. Plus, I would have no way to connect any cables.
What I am looking for (and hoping that a Netgear product would do this ) is to point my Orbi AC3000 down to the lake and have a device (ie Netgear Airbridge) that wirelessly picks up the signal and then extends it through the lake area.
Is there a way I can accomplish this?
I atttached a crude diagram of our setup. What I need is a device down at the Lake front that can pick up the signal from
the Wi-Fi extender and the main house and then increase the wi-fi coverage down the beach
