rdilauro
Jul 19, 2022Aspirant
Using two Netgear Orbi AC3000 RBS50Y to increase coverage range
We currently have on Netgear RBS50Y to extend our WiFi range from a main building down to the Lake front. Its about 750 yards. Down there I have 8 ARLO cameras connected to the same ARLO Base with ...
CrimpOn
Jul 24, 2022Guru - Experienced User
IMO the key point is whether there is electrical supply down at the lake. No electricity means no equipment (from any vendor).
In my wildest dreams I would never have imagined that those ARLO cameras would connect from 750 ft. away.
rdilauro
Jul 24, 2022Aspirant
I have AC power, but no PoEo orc cabpe (ethenert) hookup
- CrimpOnJul 24, 2022Guru - Experienced User
There is electricity at the lake. 20 of 23 cameras are connected using Ubiquiti Nanobeam. I would be looking at another Nanobeam for the last three cameras.
- rdilauroJul 24, 2022Aspirant
Down at the lake with your NanoBeam receiver, I assume you have a PoE connector and cables. On land where we use a series of NanoBeams, the last one in line connects to a PoE and from there goes to our Router via cable.
How is your NanoBeam setup down at the lake?
- rdilauroJul 27, 2022Aspirant
We have decided to go with 2 Netgear Orbi AC3000 extenders. One is already in place at the club house. I will connect the second one and bring it down to the lake front.
Question, since this is an outdoor piece of equipment, will I need a plastic enclosure to protect it from the elements?
Some say yes, others say it is not necessary, but I was hoping Netgear folks can answer this one.
