rdilauro
Jul 19, 2022Aspirant
Using two Netgear Orbi AC3000 RBS50Y to increase coverage range
We currently have on Netgear RBS50Y to extend our WiFi range from a main building down to the Lake front. Its about 750 yards. Down there I have 8 ARLO cameras connected to the same ARLO Base with ...
Jul 27, 2022Guru - Experienced User
Sadly it is a yes, no.
I've never had an issue with mine but I've seen a few posts from users that got moisture in theirs.
I think a lot depends on the environment you're in. I bring mine in during the winters in MN because it isn't rated to that cold of temps. If you're in an area or place it in a spot where it gets to hot, its going to expand from the heat out of spec and then you'll get gaps/moisture.
rdilauro
Jul 27, 2022Aspirant
SemiDumb question.
I have the Netgear ORBI App on my Iphone. When the new Orbi comes in, the app scans for any existing Orbi. Is there an option to ADD a new one?
Now the dumb question. I have a Netgear userid password (how I get to the product page), Is there a separate Netgear Orbi userid password do I need?
I have the Netgear support userid/password, Netgear Community userid/password
