stark101
Oct 25, 2018Aspirant
Ready to chuck this system through the window
Latest firmware V2.2.1.210 on AP mode.
This is the 3rd time I've tried to set this system up.
The first time my 2 LAN connected satelites suddenly switched to Wifi and refused to switch back to L...
Oct 25, 2018Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Especially if your satellites are wired to the router.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Found under Advanced Tab/Advanced/Wireless Settings
If you used the auto upate, try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
For apple issues, Try this:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
Retired_Member
Oct 25, 2018By the time you provide the answers to ALL of these questions (if you so desire) a new FW may be released.
