jpthibault
Jul 03, 2020Aspirant
Regrets, I have a few: RBR50 and ORBI21
I regret buying this pair beause an extra satellite (ORBI21) isn't avalable for purchase anywhere in Canada.
One of the reasons why I bought the pair was its claimed ability to easily expand.
It's not a bad WiFi solution, but I suspect that because it hasn't reached very high unit sales that it's expansion options have suffered.
I wish that I would have gone with a more popular solution.
jpthibault wrote:I appreciate your quick help, but I'm not sure that you understand my issue: I need a second satellite, that operates as the same speed as my exsiting two (RBS50 and RBR50) and a single RBS50 is not available in the Canadian market for sale.
You are SO right. Orbi owners are scouring the used market for additional satellites. (eBay, for example). I keep looking for another RBS50 and the asking prices are unbelievable. I have seen no comment from Netgear. The speculation seems to be (a) Netgear has shifted focus to the new WiFi6 product, and (b) this ghastly pandemic has disrupted the supply chain.
It is not pleasant situation. There are a couple of possibilities:
- Any of the original Orbi satellites will fully integrate with the Orbi RBR50 router. Depending on the internet connection speed, end users may notice no difference at all in performance. RBS20, RBS40, RBW30 all work. The RBS50Y (outdoor) model works, but the cost is prohibitive.
- Depending on your need, you can expand coverage with any brand of "WiFi extender".
For example, if the problem to be solved is some device that is slightly too far away, and never moves (such garage door opener, irrigation controller, security camera, etc.) then you can extend WiFi to just that device using a product from almost any vendor. TP-Liink's N300 2.4G extender, for example, retails for $20US.
Not what you wanted to hear. Sorry.
What is Orbi21? This isn't a model rather a SSID name possibly. Do you mean a RBS20?
- jpthibaultAspirant
Aw yes, you are correct. the model is RBS50.
F/W V2.5.1.16
I share your frustration. I love my Orbi system, but I need just one more satellite to get the full coverage I want. Should have bought a 3 unit system, but those weren't available when I bought my 2 unit system so I just want to buy one more satellelite (a RBS850 in my case). I think Netgear is having some supply chain problems. At least I hope that's what it is and they aren't intentionally keeping the add-on satellites off market.
The Orbi is great. I think this is a short term issue that Netgear is struggling with. I have inquired through many channels when the add-ons will be available and no one knows.
