Jazijia
Mar 02, 2020Aspirant
Replacement Adapter - Orbi Satellite
Hi all
I have an Orbi RBR20 system and the satellites are RBS20 model. One of the satellites power adapter has malfunctioned and is out of warranty, so I have to buy a replacement.
The model number of the adapter is 2ABB018F and I need to know the size of the plug to be able to buy the correct sized adapter. The size isn't written anywhere and I don't have the tools to measure it.
Can anyone help me with identifying the size as I am outside US and have to rely on Amazon.
Thank you
Find one on Amazon that matched the putout voltage and amps as the original one.
- JazijiaAspirantThat's the easy part and I got that. I need to know the size of connector pin that goes in the satellite.
Might look at the spec sheets to see. Most of the pin connectors are all the same and general size. Even if you do a search on replacement power adapters, the pin connector should be the same. Can ask the seller to confirm this as well.
- ReinateAspirant
i wanted to place a satellite on top of the wall cabinets on my kitchen but didn't have an outlet nearby, so i picked up this power adapter, it's really nice.
- WebheadjunkyAspirantHi dont want to hijack this thread. I am in UK. I have purchased used RBK50 set and was looking forward to setting it up. Idiot that I am, I cut the wire on one of the adapters when removing bubble wrap! Could you recommend a replacement please? There is one on Amazon that appears to be unavailable. Grateful for your advice.
Contact NG support.
https://www.netgear.com/support/#
Webheadjunky wrote:
Hi dont want to hijack this thread. I am in UK. I have purchased used RBK50 set and was looking forward to setting it up. Idiot that I am, I cut the wire on one of the adapters when removing bubble wrap! Could you recommend a replacement please? There is one on Amazon that appears to be unavailable. Grateful for your advice.- WebheadjunkyAspirantThanks. I could not see an option to raise a ticket with support? Any tips?
