w2usf
Apr 02, 2019Tutor
Reset admin password in the SET PASSWORD screen in ADMINISTRATION not working
I know my password and can sucessfully login. However the SET PASSWORD screen does not permit the change When I clink on APPLY nothing happens - no errors messages displayed and must click on cancel to escape. The old passwaod in correct and the doulble entry for the new password matches.
Tries numerous times even with a wired connection. Mine is an RBR50 with 2 satillites and the latest firmware.
This is frustrating as the password reset should be simple
What browser are you using? Try IE11, FF or Opera?
Setting a new Admin PW is working for me on the RBR50 with v44 loaded using IE11.
- Chuck_MMentor
Worked fine for me using Chrome and .44
- w2usfTutor
Thank you one all for the thoughtful comments.
I will do a factory rest as soon an I am able to retrieve the satellites that are in remote area of my home.
While the Orbi mesh system has performed admirably for some four months, I am disappointed in the Net Gear 90 support policy. Effectively it adds up to no support unless one opts in to the service contract which begins to approach the cost of the product in just a few years.
I say this because these are consumer products intended for the non-technical consumer. Leaving the end-user to their own devices- having to experiment with an array of Web browsers as some of you have suggested- is hardly a consumer-friendly product. Routine password changes are not only necessary but a vital security feature in the pervasively hostile Web environment. And such routine changes should be achieved by the popular consumer Web browsers in use. The answer is not an expensive Net Gear security product.
Knowing what I now know about mesh networks and the Net Gear ORBI, I may have well selected the Deco mesh products.
Thank you again. Spending your valuable personal time to respond is much appreciated. I’ll post the results of the hard reset
