Thekop84's avatar
Nov 01, 2018
Ring Doorbell Pro issues with Orbi
Hi guys.
I am not gifted with a great it brain I was hoping some here can help me with my issue! I have a ring door bell pro along with an Orbi and one satellite. At first the Ring connected fine with the orbi for a few days then it got disconnected. When I try to reconnect it can see the wifi name but its in red? I have a few devices connected with the Orbi and they are all working fine. Any suggestions guys? Any help will be greatly appreciated!
  • FURRYe38's avatar
    What FW is currently loaded?
    Review this as see if this helps any:
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649457/highlight/true#M43053
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
    • seanrkelly71's avatar
      seanrkelly71
      Star
      I have the Ring Video Doorbell and had a similar issue.  I learned somewhere that Ring doesnt work on 2.4Ghz Ch11, so change that channel from Auto (or if on Ch11) to something lower than 11.  Thats what I did and started working again.
      • Thekop84's avatar
        Thekop84
        Guide
        Thanks for the reply guys. I set the channel to lower then 11 but still no luck. I searched the forums and came across this. I forgot to add that I have a chime pro and it couldnt find my orbi network. After doing this my chime pro sees the network. When I tried it on my ring doorbell at first it saw it, it was in green but when It couldnt connect. I tried it again but then the network was again shown in red. Driving me crazy!
  • Hi guys,
    I ended up replacing the Ring Door Bell Pro with a brand new one and touch wood it has been working like a dram now! I have had it set up for over 4 months now without any drop outs. Perhaps it was just a faulty door bell!
    • BigDGlad's avatar
      BigDGlad
      I purchased my Orbi yesterday, set it up as normal and then telneted into it and changed the names on both the 2.4GHz & 5GHz to the names I had on my old router. I then reset the password on both to password on old router and bingo all devices set up on each SSID just like on old router. The Ring doorbell pro came online (2.4GHz) just fine and works as usual. All other devices went to 5GHz as before. Life is good and no dead spots. If you need instructions on how to Telnet, go to YouTube and search Telnet Orbi.
