Brinch's avatar
Brinch
Tutor
Apr 20, 2020
Router admin screen doesn't show same info as Orbi app
When I log into my Orbi router through a website, it says that there are no satellites connected and only 1 connected device, even though we have approximately 30 devices that are connected to the wifi.
When I log into my Orbi app, it shows that 2 satellites are connected and the appropriate amount of connected devices, but they all show up as a printer or as a google home mini.
I unplugged and plugged back in the satellites until they showed a solid blue LED, so I'm assuming they are connected to the router.
Anyone have ideas why this is? Which one should I trust?
  • Retired_Member's avatar
    Retired_Member
    orbi model number & firmware?
        Retired_Member
        Brinch wrote:
        Router firmware 2.5.1.8
        RBR50
        that's your problem.....lots of problems.....revert back
  • FURRYe38's avatar
    Whawt browser are you using?
    There is newer FW available:
    https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
