jarwilke's avatar
jarwilke
Follower
Aug 03, 2019
Router Dropping Internet Connection- CBK40-100NAS
Model: CBK40-100NAS
The system is constantly dropping the internet connection. I will power cycle and It will happen soon after.
Firmware: 2.3.5.12_1.0.8
I have confirmed with the ISP (Suddenlink) and neighbors that there are no outages in our area.
Provided the ISP with the device MAC address.
I have spent quite a bit of time with Netgear Technical support. They suggested changing the channels- didnt really help.
I have the satellite (RBS20) connected by ethernet in the basement
I have attached the event log to see if that additional information can help.
  • FURRYe38's avatar
    Is the CBR40 dropping wired internet access with a wired PC?
    Is there any top led ring inidication turning on? Pink or Blue? White?
    Bsure your using good quality RG6 coax cable between the ISP service box and the CBR40.
    Ensure there are no coax line splitters between the ISP service box and the CBR40.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    jarwilke wrote:
    Model: CBK40-100NAS
  • Mine keeps dropping connection intermittently. Everything I have read here states (thousands of complaints) that the firmware update has caused this problem. I tried to reinstall older version but upon reboot it automatically updates firmware!
    • FURRYe38's avatar
      Has a factory reset and setup from scratch been performed since last update?
      Check for coax cable line splitters in between the CBR40 and ISP service box.
  • FURRYe38's avatar
    Any updates on this?
    jarwilke wrote:
    Model: CBK40-100NAS
