DodgerJeff's avatar
DodgerJeff
Router IP changed from 192.XXX to 10.xxx
My new Orbi has changed from 192.168.1.1 to 10.0.1.1
Now I cannot connect to Orbi at all.  Tried typing in 10.0.1.1 and also I see that Mac Internet setting say IPv4 address 10.0.1.46 and that doesn't work either.
Internet speed has gone from 116Mb/s to 2Mb/s
Orbilogin.com or .net doesn't work either.
    Have you 10. is usually when it is in router mode. Have you changed to brdige/acces point mode?
    Also make sure you are on the same network to access orbi login. for example if you are a wired logi staight to anything other than your Orbi you wont be able to acces it, so change to wifi connection on orbi OR wired to orbi.
  • Orbi will change its LAN address automatically when Orbi's WAN port is assigned a WAN address that conflicts with the LAN address.  So, you must have another router between Orbi and the Internet that is assigning a private IP address in the 192.168.1.X range to Orbi's WAN port.
    Either remove that other router or run Orbi in access point mode.
    • DodgerJeff's avatar
      DodgerJeff
      I have a Netgear CM500 that is only a cable modem.  That is the only thing connected to my Orbi.
      • st_shaw's avatar
        st_shaw
        Master
        That modem has a fixed IP address of 192.168.100.1 for adminitrative access.
        What did you enter on the Orbi LAN settings for your LAN address and subnet mask?  You should enter 192.168.1.1/255.255.255.0.
        If you were to use a different subnet mask (e.g. 255.255.0.0) Orbi would exhibit this behavior.
