MattHopkins
Aug 26, 2017Guide
Router Speedtest - slow compared with other wired devices on network
In trying to understand why my wifi speeds are so slow since v1.12.0.18... I performed the SPEED TEST option from the Orbi app which uses the OOKLA Speed Test service to test the speed between the ro...
tucsontico
Aug 26, 2017Virtuoso
Several posters have found the resetting the NVRAM via telnet commands and then running a factory default reset has helped their speeds. The key appears to be NEVER RUN A SPEED TEST VIA THE BUILT-IN QoS PAGE! Apparently doing so causes ORBI to slow down preciptously. Good luck!
MattHopkins
Aug 27, 2017Guide
For the benefit of others - this resetting of the NVRAM mentioned above has made a positive impact for me on this issue. My speeds are better - still not where they should be in relation to my broadband, but better.
Thank you.
