fdease12's avatar
fdease12
Router will not accept internet from confirmed modem
Orbi will not accept Internet from Comcast, modem pinged/updated/confirmed it has connectivity.  Orbi will not grab it,  2 hours on the phome with Comcast..
(RBK50V-100NAS)
  • Retired_Member's avatar
    Retired_Member
    what kind of modem is it?  Built in router?
  • FURRYe38's avatar
    Be sure to power OFF the MODEM for 30 seconds then back on. Do same for RBR. Check internet.
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    (RBK50V-100NAS)
  • CrimpOn's avatar
    CrimpOn
    Do you have a computer that can be connected directly to the modem (PC, Mac, laptop)?
    Although Comcast "knows what they are doing", it is sometimes useful to validate.  i.e. wire a computer directly to the modem, restart the modem, (wait), start the computer, and see if it connects and "works correctly".
    After that, the next step is to power off, connect the yellow (WAN) port on the Orbi to the modem, power on modem (wait), power on Orbi, and report what you see on the "Ring Light" at the top of the Orbi: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    How do you intend to set up the Orbi (using the web interface or using the Orbi "app")?
