Rdub-mongoose
Dec 21, 2022Tutor
RWB30 no power
I think I know the answer which is my satellite is toast but figured I would check here. My router is working fine. It dropped the connection to the satellite. I tried to reset the satellite multiple ways and can’t get the ring to light up. I’m assuming it’s a brick. It’s way out of warranty. Let me know if you have any other tricks or a link to process a return (if they will allow it)
Thanks!
Thanks!
You're a little caught because the RBW30 is the only one that doesn't have an ethernet port to revive them if they get corrupt firmware or power.
Does the power light even come on at all?
did you try a 30/30/30 reset? (hold reset for 30 seconds while powered on, continue to hold reset for 30 seconds while powered off, continue to hold for 30 more seconds while powering it back on)
Thanks for the reply. I had done the 30 sec reset but didn’t know about the 30/30/30. Just tried it with no luck. I guess I have a brick that is plugged into my outlet.
Does the power light come on at all?
