danall22
Apr 02, 2020Aspirant
S10 and Orbi drop out
I have an Orbi set up running in router mode and it does not like the s10. I have over 50 devices attached and not one issue with any of the others but the s10 is constantly disconnecting from the Orbi. It says authentication error on the s10. Any ideas as it’s driving me mad...all 50+ devices are fine though!!
- Retired_Member
s10?
- danall22AspirantYes sorry a Samsung s10 mobile phone.
Try doing a IP address reserveration for the phone ON the RBRs web page. Use a web browser for this.
See if you can assign it a IP address reservation.
You can try some of these suggestions, however you may not want to both since other devices are working. You can revert back the changes:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
If ALL other devices are working with orbi and this one device isn't, then this would inidcated a problem with this S10 device? Samsung?
I would first contact the Mfr of this device and get help and support there first.
danall22 wrote:
I have an Orbi set up running in router mode and it does not like the s10. I have over 50 devices attached and not one issue with any of the others but the s10 is constantly disconnecting from the Orbi. It says authentication error on the s10. Any ideas as it’s driving me mad...all 50+ devices are fine though!! - rusty44Aspirant
Try this: https://www.megebyte.com/android-wifi-authentication-problem/
It worked for me.
- Mjsmith3TutorI tried this solution and it works temporarily and then fails. None of my other devices seen to have those issue other than my S10+. Rebooting phone solves problem temporarily, butt usually only for a few hours
