ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Sedawgie
Jul 25, 2017Initiate
I'm having the same issue. Samsung S8 reset to factory settings - no improvement. Issue is only with my Orbi. Wi-Fi works fine elsewhere. Latest firmware on orbi.
Sangwich
Jul 25, 2017Star
I don't understand why someone who actually has an S8 or S8+ tell us to factory reset our phones. It doesn't work! I mentioned this before. Don't factory reset your S8 or S8+.
The issue is clearly the Orbi. Constant disconnection for S8/S8+ is not the only issue. My 5Ghz radio doesn't work anymore. I factory reset my Orbi router, satellite and my S8+. None of them works. Rolling back to an older firmware fixed most of the issue but there are people in my household that have an iPhone. So I rolled back and tried the guest account. That worked for me!
S8 and S8+ owners. Try creating a guest network and connect your phone there. My phone hasn't disconnected the past 2 or 3 days.
Anyone else not able to connect to the 5Ghz radio? I disconnected and reconnected and used my phone in front of my router and satellite but I can never connect to the 5Ghz. None of NY devices can connect to it. I factory resetted at least 2 times and still no luck. I can only connect to it if I roll back my firmware.
