ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
DarrenM
Jul 27, 2017Sr. NETGEAR Moderator
We are investigating the issues with the S8. will let you know when I have a update or a fix but right now the work around is to connect it to the guest network many customer have reported that to work.
DarrenM
toddbee
Jul 27, 2017Guide
I am having the same issue. All devices work fine except the Glaaxy s8 Plus. Connects and disconnects all the time. I get the wifi signal on the phone with the exclamation point thru it. The S8 works everywhere except on this Orbi. Hard to believe that its not an easy fix on Netgears end. I will try the guest account, hoping it will do the trick for now.
