ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
tjnixon2017
Jul 29, 2017Guide
Same problem after the recent update for the Galaxy S8 getting disconnects. Never a problem before the update release from Verizon this past week.
toddbee
Jul 29, 2017Guide
Hi all,
So I added a guest network and now my galaxy s8 plus appears to be working and not disconnecting. Seems like this is a work around until it gets patched.
- cleoentJul 29, 2017InitiateSame problem here since Verizon update.
- littletechgirlAug 22, 2017Guide
Same exact issue here on my S8+. It started happening about a month or so ago after a phone update. I just completely reset my Orbi to default and set it up again. It is still happening. I am not resetting the phone.
- MattymeatballAug 22, 2017Tutor
Okay, so I found a solution that said to set up a guest network (make sure to PW protect it) and I named it something other than "guest" so that other people in the area don't try to use it. Once I did that and connected to that "guest" network, the connection has worked like a charm. Give it a shot...
Thanks. I will give this a try. I have an Xfinity Router and if I connect to the WiFi on that instead of the Orbi it works great. Of course I prefer that the Orbi work.
- Sellmetv2Aug 27, 2017TutorI am also having the same issue, this is the 2nd Orbi system I am using. Returned the first one and set up the 2nd system. Both systems have the same problem. However the 2nd one does not drop as much.
