ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Davidyc
Jul 30, 2017Initiate
I've had the s8 plus problem for awhile on tmobile. After tmobile knew nothing, they directed me to samsung. Who after a couple people said i should update to the latest android update. 7.01 or something.
Probably can check by updating software in settings.
I have since done this, and it does appear better. Hope it lasts. It's been so frustrating, that I decided to post and see if it helps others.
Disturbd1
Jul 30, 2017Star
I can tell you this is definitely not related to the version of Android on our phones. My girlfriend has the S7 Active, and it is on version 7.0, and does not have any issues with wifi connectivity. As others have stated, this is specific to the S8/+ and the Orbi.
I can also tell you it isn't a problem with the handoff between bands/frequencies. I've completely disabled the 2.4gHz range just to test this, the problem persists.
