ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Disturbd1
Jul 30, 2017Star
Davidyc wrote:
I've had the s8 plus problem for awhile on tmobile. After tmobile knew nothing, they directed me to samsung. Who after a couple people said i should update to the latest android update. 7.01 or something.
Probably can check by updating software in settings.
I have since done this, and it does appear better. Hope it lasts. It's been so frustrating, that I decided to post and see if it helps others.
I can tell you this is definitely not related to the version of Android on our phones. My girlfriend has the S7 Active, and it is on version 7.0, and does not have any issues with wifi connectivity. As others have stated, this is specific to the S8/+ and the Orbi.
I can also tell you it isn't a problem with the handoff between bands/frequencies. I've completely disabled the 2.4gHz range just to test this, the problem persists.
Stkasm
Jul 30, 2017Apprentice
Disturbd1 wrote:
.I can tell you this is definitely not related to the version of Android on our phones. My girlfriend has the S7 Active, and it is on version 7.0, and does not have any issues with wifi connectivity. As others have stated, this is specific to the S8/+ and the Orbi.
So, it's a problem with S8. Just search the Internet and check Samsung forums. People with S8 and Google Wi-Fi and other systems where they have more than one AP complain about this very problem. I have the same problem at work with Aerohive networks but it's not as severe as in Orbi environment.
It started for me and some other users after most recent S8 update from Verizon. Statement that Android version doesn't matter is only partially correct. Android uses drivers in most cases supplied by chips manufacturer or device manufacturer. Two different phones on the same Android may behave differently.
Also, I'm not quite sure how you 'disabled' 2.4G. It would be awesome to know if it's even possible on Orbi via UI. 'Broadcast SSID' doesn't disable the network.
