ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
rgrimm
Jul 23, 2017Aspirant
I had this problem. Wiping the phone's cache partition seems to have fixed it. Perhaps the phone retains a wifi setting from the previous firmware that doesn't work well with the new firmware.
Hector0125
Aug 01, 2017Guide
Thanks for that tip. I was also having issues with my galaxy s8 plus diconnecting from ORBI Wi-Fi. I followed your post and did a Network Settings Reset and that seems to solve the problem. I have been connected to ORBI Wi_Fi for hours now, browsing the web, youtube, etc and working fine. Thanks again. I will post again in a couple of days with updates if anything happens with galaxy s8 plus.
- rkolesarAug 01, 2017Star
Network Settings reset did not help in my case.
Guest Network is the only way to stay connected but thats not a solution because then I cant get access to devices on my normal network.
- SorvenAug 01, 2017Initiate
BTW - Guest mode should work for you if you enable the ORBI setting "Allow guests to see each other and access my local network" under Basic / Guest Network in router menu.
It allows devices on guest mode to see the main network devices (like Sonos). Just remember not to give out guest mode to others you don't want to open that access to. It's the only workaround until Samsung fixes their software.
- climbingxAug 01, 2017TutorThanks for the heads up.
