ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Sorven
Aug 02, 2017Initiate
BTW - Guest mode should work for you if you enable the ORBI setting "Allow guests to see each other and access my local network" under Basic / Guest Network in router menu.
It allows devices on guest mode to see the main network devices (like Sonos). Just remember not to give out guest mode to others you don't want to open that access to. It's the only workaround until Samsung fixes their software.
rkolesar
Aug 02, 2017Star
Thanks Sorven, that helped a lot!
