ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
climbingx
Aug 02, 2017Tutor
Be interesting to hear if that actually works. I reset the main router but not the sats. Will have to try that later.
mkenny28
Aug 02, 2017Apprentice
climbingx wrote:Be interesting to hear if that actually works. I reset the main router but not the sats. Will have to try that later.
Well I didn't physically reset the satellites. I just powered my whole system off and then Started router and satellites back up in order from closest to router to furthest. So turn router on, then closest sat, then next one, etc.
- Dustin278Aug 02, 2017Apprentice
mkenny28 - so you didn't actually do a factory reset? More like you unplugged all then replugged in the router followed by the satellites?
- mkenny28Aug 02, 2017Apprentice
Dustin278 wrote:mkenny28 - so you didn't actually do a factory reset? More like you unplugged all then replugged in the router followed by the satellites?
Correct. Although I did reset my furthest Satellite (an RBW30) with a paper clip and reconnect it but I doubt that did anything as my phone never connected to that one anyway. I have done multiple power cycles as well.
