ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
ElMagoFrank
Aug 02, 2017Aspirant
Add me to the list having problems with constant dropping of internet connection on a Galaxy S8+ (WiFi connected with exclamation point). I am on the latest firmware for both the Orbi (1.12.0.18) and my T-Mobile S8+. It only seems to happen when I am connected to one particular satellite in my house. Disabling WiFi and re-enabling it on the phone seems to allow it to have internet access for a brief second. Other devices connected to the satellite work without issue.
- Dustin278Aug 02, 2017Apprentice
I seemed to have fixed my dropping connection on my S8 by resetting each satellite with a paperclip then re-syncing the satellite to the router.. I will keep you posted.
- vargoose84Aug 03, 2017Initiate
I don't have any satellites and am on v.18. I've full factory resets of the router to no avail. Hopefully this can be fixed soon, it's annoying.
- ameetpAug 10, 2017Guide
My Samsung S8 drops wifi with the orbi router, since the last update from netgear.
We need a fix. This is a netgear problem
- Dustin278Aug 03, 2017Apprentice
UPDATE - after resetting each satellite with a paperclip then re-syncing the satellite to the router.. - Still having problems..
