ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Dustin278
Aug 02, 2017Apprentice
I seemed to have fixed my dropping connection on my S8 by resetting each satellite with a paperclip then re-syncing the satellite to the router.. I will keep you posted.
Dustin278
Aug 03, 2017Apprentice
UPDATE - after resetting each satellite with a paperclip then re-syncing the satellite to the router.. - Still having problems..
- mkenny28Aug 03, 2017Apprentice
Dustin278 wrote:UPDATE - after resetting each satellite with a paperclip then re-syncing the satellite to the router.. - Still having problems..
My S8 connection problems started again this morning so whatever my resets did were temporary.
- Dustin278Aug 03, 2017Apprentice
I have setup guest wifi for the time being and this has worked until they get this fixed.
- OrigosisAug 04, 2017Guide
My Samsung S8+ is also unable to maintain a connection to the router. it is so bad now, it never works for more than 2-5 seconds before it drops. I have not tried the guest WiFi yet, but I will try it when i get home tonight.
I just wanted to post to inform Netgear that there are many of us with this issue and to please have it fixed as soon as possible. $400 router + $800 phone not working, makes for one extremely unhappy customer.
