ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
nicksterling
Aug 09, 2017Initiate
I just recently upgraded to the S8 and I'm also experiencing this issue. I'm using the guest wifi trick and that's working so far but this is definitely a frustrating bug. I'm hoping to see a resolution to this soon.
- lwestfallAug 09, 2017GuideSame problem with my S8+! Unfortunately the guest network "workaround" does not allow me to control/access my numerous wifi-connected devices.
Netgear Admin: Has Samsung told you they are working on a fix on their end, or are you working on a fix on your end?- drot84Aug 10, 2017Initiate
Also started experiencing the wifi issue after updating my Verizon Galaxy S8 plus to the new firmware around July 27. Not a happy camper! At least I'm on unlimited data.
Also, lwestfall as someone mentioned earlier, the Orbi guest wifi CAN access at least some things on the main network if you check "Allow guests to see each other and access my local network" - I just started trying the guest network and was able to access a Roku on the main network. Hopefully that helps you.
- Disturbd1Aug 10, 2017StarThis is very clearly not a priority for Netgear. Even if the problem is in fact within the software running on the Samsung devices, it is not impacting other routers that I've heard. Netgear is going to lose a lot of current and potentially longstanding customers by ignoring this.
If a rep at least assured that it is being addressed, I'd feel OK about waiting. It's been weeks. I'm going to do what I need to return this and replace it.
