ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
drot84
Aug 10, 2017Initiate
Also started experiencing the wifi issue after updating my Verizon Galaxy S8 plus to the new firmware around July 27. Not a happy camper! At least I'm on unlimited data.
Also, lwestfall as someone mentioned earlier, the Orbi guest wifi CAN access at least some things on the main network if you check "Allow guests to see each other and access my local network" - I just started trying the guest network and was able to access a Roku on the main network. Hopefully that helps you.
Disturbd1
Aug 10, 2017Star
This is very clearly not a priority for Netgear. Even if the problem is in fact within the software running on the Samsung devices, it is not impacting other routers that I've heard. Netgear is going to lose a lot of current and potentially longstanding customers by ignoring this.
If a rep at least assured that it is being addressed, I'd feel OK about waiting. It's been weeks. I'm going to do what I need to return this and replace it.
- Dustin278Aug 10, 2017Apprentice
Netgears engineers know about this and here is my latest response from Level 2 support:
Thank you for sending this, we will reach out and request to test a beta firmware once our engineers provides us a copy.
For now I cannot provide yet an ETA but I will update you as soon as I receive feedback from our engineering team.
Jayson
