ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
ameetp
Aug 10, 2017Guide
My Samsung S8 drops wifi with the orbi router, since the last update from netgear.
We need a fix. This is a netgear problem
JMU1998
Aug 10, 2017Luminary
I can confirm also my new Samsung S8 Plus (version) is exhibits same issue factory reset did not help. I have no use for guest wireless so I can't turn it on to add additional interference to my environment they already took away the ability to adjust radio power and turn off no needed radios. no I will not turn on guest wireless need proper fix paid $500 got a half cooked meal!
- lwestfallAug 12, 2017GuideYes, I just confirmed I definitely get slower performance on the guest Network. This S8/S8+ issue has got to be resolved ASAP!
- lwestfallAug 12, 2017GuideActually, in all fairness, reconnecting to the guest Network I can sometimes get nearly equivalent speeds. But obviously we shouldn't have to be limited to using a guest Network to be able to use this expensive system.
- StkasmAug 13, 2017ApprenticeIt a bit unclear why it takes that much time to find why guest network with the same security settings works but normal doesn't.
